Author Topic: Mega Player 515 Bad Flash - SOLUTION  (Read 20789 times)
Mr.TomaTo
« on: 01-July-05, 17:55:11 »
I have mega 515 and mega 515 lite. And I by mistake upgrade a firmware from 515 lite into 515 :wall: ! Can I somehow repair? On 515 is always bothing(black screen) :cry: !!! Please help!!!thanks
alarmyst
Re: mega 515
« Reply #1 on: 03-July-05, 17:12:17 »
wait until batteries go down, then reformat
npoljak
  • CORPORAL
Re: mega 515
« Reply #2 on: 28-July-05, 14:33:40 »
  • Best Answer
  • I have a similar problem, as well. How can the batteries go out if the screen is blank and there is no indication the player is on?
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    Re: mega 515
    « Reply #3 on: 28-July-05, 18:25:13 »
  • Best Answer
  • https://forum-en.msi.com/index.php?topic=80123.0
    alick has been making lots of suggestions about firmware recovery here, but as yet no one has responded to say if it worked or not. maybe you should try it and give some feedback?
    npoljak
    • CORPORAL
    Re: mega 515
    « Reply #4 on: 28-July-05, 20:26:02 »
  • Best Answer
  • Suggestions indeed...
    I scanned through every thread I could find, tried every solution and came up with nothing....
    Problems, problems, and problems
    Mr.TomaTo
    Re: mega 515
    « Reply #5 on: 02-August-05, 14:53:11 »
    Hi all,
    somethink new?
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    Re: mega 515
    « Reply #6 on: 02-August-05, 15:10:40 »
  • Best Answer
  • did you try to recover the firmware as described in the link?
    npoljak
    • CORPORAL
    Re: mega 515
    « Reply #7 on: 03-August-05, 14:22:03 »
  • Best Answer
  • This product has already stopped production......so I only have three solutions left for your reference!!!
    1.Pressing enter "FM / A->B key" + "REC key" will rebooting!! please try again...
    2.Reseting power plug
    3.Firmware update!!!
      The Website: http://www.msi.com.tw/program/products/ia/ia/pro_ia_detail.php?UID=613
    Hope to solve your question!!!
    _______________________________________ ______________
    Like I said, I tried every solution I could find.
    Tried number 1. What the hell is #2 supposed to mean? As for #3, how am I supposed to update firmware if the player is dead, and doesn't come up as coonected via the USB port?
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    Re: mega 515
    « Reply #8 on: 03-August-05, 14:44:11 »
  • Best Answer
  • if it is still under warranty, then return it to your supplier, or RMA it through MSI
    alick
    • SECOND LIEUTENANT
    Re: mega 515
    « Reply #9 on: 03-August-05, 20:44:41 »
  • Best Answer
  • Firmware update correct process:
    1.Please download and install the latest firmware and driver!!(http://www.msi.com.tw/program/products/ia/ia/pro_ia_detail.php?UID=564)
    2.After firmware installing will show some files, please cover driver installing files(C:\Program Files\MSI\MS-5515)
    3.Please plug your mega player 515 in your PC
    4.Press “play key” continuously. (While mega player can't be recognized by PC, please add this procedure!!)
    5.Please enter OS "start" (below left corner) and enter "programing collecting" and choose to "MSI MS-5515" update now!!!
    5.After update success you can release of your hands (While mega player can't be recognized by PC, please add this procedure!!)
    Please try again!!!
    Hope to solve your issue!!
    Mr.TomaTo
    Re: mega 515
    « Reply #10 on: 04-August-05, 05:53:43 »
    How I "Reseting power plug "? Thx X-((
    npoljak
    • CORPORAL
    Re: mega 515
    « Reply #11 on: 04-August-05, 09:18:31 »
  • Best Answer
  • Yes, it is still under warranty, i bought it less than 3 weeks ago. I might just have to send it back:(
    I have tried everything, even pressing the play key while it is plugged in. I also tried holding the play key for a longer period of time. The player still does not respond or is recognized by the computer.
    If any of you have more suggestiong, please help.
    Anything but sending it back for repare under warranty:P
    Thanks
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    Re: mega 515
    « Reply #12 on: 04-August-05, 12:22:18 »
  • Best Answer
  • have you tried removing the battery and connecting it to your PC?
    if it is three weeks old and you still have the receipt, you should be able to take it back where you purchased it from for a replacement / refund
    npoljak
    • CORPORAL
    Re: mega 515
    « Reply #13 on: 05-August-05, 13:05:14 »
  • Best Answer
  • The battery is built-in and not removable, I'm afraid...
    I guess I will have to find the receipt and wait around for weeks:(
    npoljak
    • CORPORAL
    Re: mega 515
    « Reply #14 on: 12-August-05, 19:46:48 »
  • Best Answer
  • OMG. I FIXED IT. BY ACCIDENT.
    1. Hold down the power button and keep doing so
    2. Plug it into your computer via the USB cable (while holding the power button)
    3. The computer should recognize the player and start installing drivers called "mp3 player recovery" or something like that (you may need to  download drivers via windows update)
    4. Once the installation of the recovery drivers is complete, run the Firmware update software that came with the MP3 player and update the firmware normally...
    ALL DONE! FINALLY!
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    Re: mega 515
    « Reply #15 on: 13-August-05, 05:07:20 »
  • Best Answer
  • thank you for sharing your solution, hopefully this will help many others! :biggthumbsup:
    for now, i think this deserves sticky status
    bassmadrigal
    • LIEUTENANT COLONEL
    • Giggidy, Giggidy, Gig-gi-dy
      • bassmadrigal's blog
    Re: mega 515
    « Reply #16 on: 13-August-05, 06:22:51 »
  • Best Answer
  • Glad you were able to sort it out. :biggthumbsup:
    for know, i think this deserves sticky status
    You may want to change the subject so it is a bit more informative. Something like "Bad Flash Mega 515 - Solved".
    Have Fun
    Jeremy
    If you drop your keys in molten lava, forget them; because, man, there gone!
    MSI K9A2 Platinum
    AMD Athlon 64 X2 6400+
    4GB Corsair XMS2 DDR2 800
    Diamond ATI HD3870
    SoundBlaster X-Fi Xtremegamer
    2x1TB, 1x500GB, 1x320GB, 1x250GB, 1x150GB Western Digital SATA
    Coolermaster 1200W PSU +3.3V@30A,+5V@30A,+12V1@20A,+12V2@20A,+12V3@25A,+12V4@25A
    ThermalTake Armor 8000 Full Tower
    Samsung SyncMaster 940BX 19" LCD 1280x1024
    Hanns-G HG281D 28" Widescreen LCD 1920X1200
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    Re: Mega Player 515 Bad Flash - SOLUTION
    « Reply #17 on: 13-August-05, 06:45:03 »
  • Best Answer
  • :biggthumbsup: done!
    Mr.TomaTo
    « Reply #18 on: 01-April-06, 11:55:20 »
    Hellooooo :agrees:! Great job guys :worship:
    Sicky
    « Reply #19 on: 05-January-07, 15:37:45 »
    I own MSI Mega Player 515.
    I have some problems like Mr.TomaTo.
    After i succesufuly update Firmware my player show 256 Mb of memory instead 512 Mb.
    Plaese Help!
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #20 on: 06-January-07, 07:45:29 »
  • Best Answer
  • Logged
    Sicky
    « Reply #21 on: 06-January-07, 10:19:27 »
    I don't know. I try with this link. Thanks
    I't was that Firmware. Another suggestion. Thanks
    Please help.
    Sicky
    « Reply #22 on: 07-January-07, 15:49:03 »
    Some people tell my to do low level format on my player.
    FunkyMonk
    Mega Player 515
    « Reply #23 on: 18-October-07, 05:37:30 »
  • Best Answer
  • Hello!
    I have a problem with my ms-5515. My PC doesn't recognize it at all, and I cannot turn the player on either.
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #24 on: 18-October-07, 17:58:04 »
  • Best Answer
  • FunkyMonk,
    Have you actually read through this topic and tried anything suggested here?
    flights_of_fantasy
    • [url=http://www.tbnlogistic.ru/]ñáîðíûå ãðóçû, ïåðåâîçêà ñáîðíûõ ãðóçîâ[/url]
    Mega Player 515 Bad Flash SOLUTION
    « Reply #25 on: 11-December-09, 13:51:18 »
  • Best Answer
  • anybody know any solution
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #26 on: 12-December-09, 05:54:01 »
  • Best Answer
  • Have you actually read the whole thread? :wall: :think:
