Author Topic: Other MSI Products - before posting, please read  (Read 12014 times)
StuTopic starter
  • Birmingham, UK
    • StuOnline.co.uk
Hi there!
This forum is where you can find help for all the other little devices that MSI produces that don't have a home elsewhere in this forum.
These devices include MegaPlayer, MegaStick and MegaView MP3 / Portable Media Players, and MSI's communication devices, such as Bluetooth dongles and Wireless LAN routers & cards as well as StarCam, MegaCache, PocketDTV etc.
Before posting your question, read the Forum Rules, and use the button to see if your question has been answered already. But please don't hijack old dead threads, start your own new topic, giving as much information as you can, as well as what you have tried already. Posting to a two year old thread saying "i have same problem, did you ever fix it??" won't help at all. Read any stickies that have been posted here already, they may contain valuable information to solve your problem.
Have you read the manual? The manual supplied with your product is usually just a multi-language Quick Guide. Look on MSI's Product Support Pages (http://global.msi.com.tw/index.php?func=prodindex). You can find updated complete manuals, which will usually contain more information than the one supplied in the box. You would be surprised how many questions posted here can be answered just by looking in the manual! You can also find the latest drivers and firmware there, as well as popular FAQs.
If your problem is related to using your device with your PC, then please post full system specs, in case your problem is actually caused by your PC.
There's a good possibility that as this is a user-to-user forum, and no-one from MSI visits here, there are no answers yet, or nobody is able to help you yet. In that case, your best option is to contact MSI Support themselves, and see if they can help you with your problem.
Find MSI Support links here: https://forum-en.msi.com/index.php?topic=107326.0
Please note, that when contacting MSI Support, you should describe the problem as clearly as you would here, and give as much background information as you can. If you write to them "my MegaStick doesn't work, what can i do", then don't complain if you get a stock generic reply back from them :-P).
Please, if you get an answer from MSI that solves your problem, or helps you to fix the problem yourself, join the helper's club here and post your solution, so that others can benefit from your wisdom!
Thank you, and good luck! :biggthumbsup:
