Author Topic: NVIDIA boot agent 201.0440  (Read 3639 times)
HurrayBeerTopic starter
« on: 27-July-05, 23:30:23 »
Hello , Here is my problem , I get to (boot from CD....) then I get
(NVIDIA Boot Agent 201.0440
 copyright(C)2001-2004 NVIDIA Corporation
 copyright (C) 1997-2000 Intel corporation
 PXE-E61:Media Test Failure check cable
 Pxe-MOF:Exiting NVIDIA Boot Agent
 Disk boot failure , insert system disk and press enter)
I have had this system going for about 4 months now and have had no problems , then I started getting a blue screen and self rebot.
 Any ideas?
K7N2 delta2
AMD 3000+
Antec true 430W
Corsair pc2700 1G
Radeon 9600SE
please help or my wife will kill me if I don't fix it. thank you
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #1 on: 27-July-05, 23:40:18 »
this means that the mobo is attempting to boot from the LAN, and is failing because a network cable is disconnected
check your boot order in BIOS hasn't been changed by mistake (make sure HDD is first). check all connections to HDD. is HDD recognised in BIOS?
osnavi
  • GENERAL
« Reply #2 on: 27-July-05, 23:44:43 »
"...Disk boot failure , insert system disk and press enter..."  Do you have any HDD installed ? Any as boot drive ? What o/s installed ?
MSI KT3 Ultra 2 ARU
Athlon XP 2800+Thermaltake Heatsink fan
2x 512 Mb DDR PC 2700 Spect
MSI FX 5900XT 128 Mb
SBlaster Audigy Platinum
HDD 0 Maxtor80Gb HDD1 Maxtor120Gb both Ata 133-7200 RPM
USB 2.0 HDD 80 Gb.
MSI CDR 52x
Aopen CDRW 48x12x50x
Pinnacle DV500 VidEditor
Thermaltake 420W 3.3v.-30A 5v.-40 A 12v-18A
USB 1.1 Memory Stick Card Reader
Floppy Drive
PS2 & USBMouse
WXP SP1
Fredrik
  • There's always a risk.
« Reply #3 on: 27-July-05, 23:55:48 »
You beat me to it yet again: Boot order's the word.
Please, as suggested, also check that the jumpering on the hard disk(s) correspond with the placing.
A similar problem can sometimes occur if the Windows installation was not completed successfully. Not that it is that, but thought I'd mention it.
« Reply #4 on: 28-July-05, 00:33:16 »
Ok , I was trying to format another hard drive and got the same thing , then read the posts , I changed  the boot order and also disabled (MAC LAN (nVidia) )and got BOOT FAILURE exc... and saw that I neded to set to master so I did. I got it to bot and enter windows with new hard drive .(windos 2000 pro)  I tried to make first hard drive a slave but it would not get pased the first set of info, Esc to enter bios part so removed it .
thank you for the help , now my wife gets to reinstall EVERY THING. (giggles)
Fredrik
« Reply #5 on: 28-July-05, 00:53:56 »
She'll enjoy that, I'm sure. :grin:  You are so welcome!
