Author Topic: Insufficient extended memory?  (Read 1874 times)
newbie222
« on: 26-August-05, 23:25:41 »
I am trying to flash my bios - windows me startdisk but when i start the command from the virtual Ram drive it says insufficient extended memory. Should I expand the "extended memory" in some way and what to do to flash my bios
PS i read the forum topics already and also sent a message to tiresmoke but no help so far
Tiresmoke
« Reply #1 on: 27-August-05, 00:20:38 »
I do noyt give private help as that does not help others.
It sounds like you have the Config.sys file fouled up in a DOS startup disl. Or you are trying to flash using a DOS program in Windows.
Personally my suggest is always to have Live Update create a Bios Flash Diskette. Not to have Live update to flash it for you though. Then use the diskette that was created to boot from. This way you get a disk that will work and that sets up a RAMdisk that you actually flash from.
Supershanks
  • LIEUTENANT GENERAL
  • Manchester U.K. Help us help U post specs.
« Reply #2 on: 27-August-05, 00:41:45 »
  • Best Answer
  • Ensure you follow instructions here
    Flashing the BIOS for Users using NON FAT file system
    Visit  www.bootdisk.com in step 5) to ensure you have a dos boot that can create a ram drive without issues.
    luck :-))
