Author Topic: Toshiba DVD CD-R combo drive won't burn CDs  (Read 3028 times)
Dietcoke
« on: 12-September-05, 19:59:13 »
 :confused2: Help,
    My Toshiba DVD-ROM / CD-R COMBO internal drive will not burn CDs. I have disabled the WIN XP service IMAPI CD-Burning servicem, but still it will not burn CDs. It used to work OK.
 Its a  SD-R5112 model.
Apologies to the moderator, if this is posted incorrectly, I'm not a frequent user.
System configuration:
****************System Information****************
[MSI_Info]
OS Version:      WinXP
LUS Version:      3.73.000
Language:      2057
MB Model Name:      MS-6593
MB BIOS Vendor:      AMIBIOS
MB BIOS Version:   1.50
VGA Model Name:      UNKNOWN
VGA Driver Version:   UNKNOWN
VGA MSI Version:
VGA BIOS Version:   UNKNOWN
[OS]
Name:         Microsoft Windows XP Professional|C:\WINDOWS|\Device\Harddisk0\Partition1
Manufacturer:      Microsoft Corporation
Version:      5.1.2600
CSD Version:      Service Pack 2
Windows Directory:   C:\WINDOWS
Boot Device:      \Device\HarddiskVolume1
Total Virtual Memory:   2048 MB
Free Virtual Memory:   2008 MB
Total Visible Memory:   512 MB
Free Physical Memory:   231 MB
Serial Number:
Install Date:      08/07/2003
Current Time Zone:   Paris , Belgrade , West Central Africa
Locale:         0409
State:         OK
[System]
User Name:      WINXP-STEVE
Description:      AT/AT COMPATIBLE
Model:         MS-6593
Manufacturer:      MSI
Number Of Processors:   1
Total Physical Memory:   512 MB
System Type:      X86-based PC
System Wake Up Type:   APM Timer
Power Supply State:   2
Power Manage. Support:   null
Bootup State:      Normal boot
[BIOS]
Manufacturer:      American Megatrends Inc.
Version:      AMIINT - 10
Serial Number:      00000000
Release Date:      04/02/2001
Target Operat System:   Unknown
Language:         English
State:         OK
[CPU]
Name:         AMD Athlon(tm) XP 2000+
Description:      x86 Family 6 Model 6 Stepping 2
Manufacturer:      AuthenticAMD
Processor Type:      Central Processor
Version:      Model 6, Stepping 2
Data Width:      32 Bits
Socket Designation:   Socket-A
Processor Id:      0000005500000662
Processor Family:   Power PC 604
Processor Stepping:   2
Max Clock Speed:   1670 MHz
Current Clock Speed:   1670 MHz
Current Voltage:   0 V
External Clock:      133 MHz
L2 Cache Size:      256 Kb
Availability:      Running/Full Power
Power Manage. Support:   false
State:         OK
[Memory]
Memory Device Locator:   DIMM1
Memory Bank Label:   RAS 0 & 1
Memory Capacity:   512 MB
Memory Total Width:   null Bits
Memory Data Width:   null Bits
Memory Type:      3DRAM
[Mainboard]
Manufacturer:      MSI
Product Name:      MS-6593
Version:      1.0
[Sound Device]
Name:         Realtek AC'97 Audio for VIA (R) Audio Controller
Manufacturer:      Realtek
Product Name:      Realtek AC'97 Audio for VIA (R) Audio Controller
Availability:      undefined
State:         OK
[Network Adapter]
Name:         Realtek RTL8029(AS)-based Ethernet Adapter (Generic)
Product Name:      Realtek RTL8029(AS)-based Ethernet Adapter (Generic)
State:         null
Name:         1394 Net Adapter
Product Name:      1394 Net Adapter
State:         null
Name:         RAS Async Adapter
Manufacturer:      null
Product Name:      RAS Async Adapter
State:         null
Name:         Packet Scheduler Miniport
Product Name:      Packet Scheduler Miniport
State:         null
Name:         WAN Miniport (L2TP)
Product Name:      WAN Miniport (L2TP)
State:         null
Name:         WAN Miniport (PPTP)
Product Name:      WAN Miniport (PPTP)
State:         null
Name:         WAN Miniport (PPPOE)
Product Name:      WAN Miniport (PPPOE)
State:         null
Product Name:      Direct Parallel
State:         null
Name:         WAN Miniport (IP)
Product Name:      WAN Miniport (IP)
State:         null
State:         null
Name:         Microsoft TV/Video Connection
Manufacturer:      null
Product Name:      Microsoft TV/Video Connection
State:         null
[Video Controller]
Name:         NVIDIA GeForce2 MX 200
Current Refresh Rate:   72 Hz
Installed Drivers:   nv4_disp.dll
Driver Version:      6.14.10.5216
Inf File name:      oem7.inf
Monochrome:      false
State:         OK
[Video Configuration]
Assaf
  • GENERAL
« Reply #1 on: 13-September-05, 14:54:03 »
  • Best Answer
  • What software are you using to try and burn?
    Dietcoke
    « Reply #2 on: 13-September-05, 17:58:36 »
    My DVD / CD burning software is Nero Express. Thanks
    Assaf
    • GENERAL
    « Reply #3 on: 14-September-05, 22:52:40 »
  • Best Answer
  • Did you disable the simulation before writing?
    Does your writer show up as an available writing device?
    If not update your software from nero.com
    If you are using a non administrator account you need to grant it writing permissions using Nero burn rights (downloaded here)
    Dietcoke
    « Reply #4 on: 15-September-05, 08:10:59 »
    Thanks for your help Assaf. How do I disable the simulation before writing, as you suggest ? The Drive looks to be OK from an operating system point of view.
    Assaf
    • GENERAL
    « Reply #5 on: 16-September-05, 21:39:05 »
  • Best Answer
  • Apperantly there is no simulation option in the express version.
    When you go to burn, after you add the files and move to the next step is your burner available ?
    Dietcoke
    « Reply #6 on: 21-September-05, 07:39:01 »
    It shows two devices in the drop down box, neither of which will burn a CD :
    Image Recorder (CD-R/RW)
    E: TOSHIBA DVD ROM SD-R5112 (CD-R/RW)
    Assaf
    • GENERAL
    « Reply #7 on: 21-September-05, 15:03:10 »
  • Best Answer
  • The trive is there obviously (E:Toshiba...).
    What happens exactly when you press the burn button? (crash, seems like burning but CD is empty at the end, error message....).
    Dietcoke
    « Reply #8 on: 21-September-05, 20:04:32 »
    Hi Assaf,
    The burn process appears to work ,but afterwards, there is nothing on the CD. I get no error message, nothing to help me at all.
    Thanks for your help.
    Dietcoke
    « Reply #9 on: 25-September-05, 19:53:56 »
    I downloaded the Nero BurnRights from the link in your reply. I installed it. After I installed it and re-booted my PC, there was no Nero group to add users to. Or if there was I can't find a way of adding users to the Nero group.
    If I look in the system event  log, there are lots of times where the cdrom shows and error. If I double click on the event entry, it says "The device, \Device\CdRom0, has a bad block " . If I look this up, it suggests that the drive may need to be cleaned. So I cleaned it with a CD cleaning disc. It made no differance.
    Help !
    Dietcoke
    « Reply #10 on: 30-September-05, 20:46:06 »
    I spoke to TOSHIBA and they said that the driver for the VIA BUS MASTER IDE Controller needed to be the mobo or chipset manufacturer, not Microsoft. Mine has a Microsoft driver. Where do I get the MSI driver(s).
    Any ideas ?
    Wonkanoby
    « Reply #11 on: 30-September-05, 21:19:02 »
  • Best Answer
  • VIA Drivers
    via 4 in 1
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    Dietcoke
    « Reply #12 on: 05-October-05, 07:35:16 »
    Is the PSU rating relevant, I can still burn DVDs on the same drive?
    Also, how do I create a signature ?
    Mike
    • aka Frankenputer
    • Virginia, USA
    « Reply #13 on: 05-October-05, 14:17:15 »
  • Best Answer
  • Click on the Profile button. In your profile under Modify Profile, click Forum Profile Information and fill in the signature field. When you're finished, click Change Profile.
    #2:
    MSI Wind U100
