Author Topic: Installed 2 version of Bluetooth driver  (Read 1890 times)
youngboyguy
« on: 23-September-05, 04:30:12 »
Hi all:
I had installed 2 version of bluetooth driver from this page:
http://www.msi.com.tw/program/support/driver/dvr/spt_dvr_list.php?part=8&kind=23&CHIP=23&ID=8
At first is the Microsoft verion, then i found it was not user friendly, then i try to remove it, but failed. Then i install another verion which is Version: 1.3.1 from the same page also. Now, i cannot use for the Version: 1.3.1 also, the bluetooth always connected to the Microsoft version driver.
As you can see at the system tray, the Bluetooth icon that turn RED is Version 1.3.1, and the another one is Microsoft version, whcih i wish to remove it.
Could anyone please teach me to remove the Microsoft version bluetooth driver? Thanks  :angel:
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #1 on: 23-September-05, 12:52:09 »
  • Best Answer
  • go to device manager, under Bluetooth Radios, right-click the Generic Microsoft device,and choose UpdateDriver...
    choose to install a driver manually, and then click on Have Disk. point to where you have downloaded and extracted the MSI drivers, and select the correct driver. fingers crossed that should work, cos i had to do something similar with my brother's bluetooth USB adaptor
    youngboyguy
    « Reply #2 on: 24-September-05, 02:33:27 »
    Thanks for reply Dr. Stu. That's the problem, i dun see any category related to Bluetooth in Device Manager. :nooo:  :wall:  I could't find it as u can see in the picture. Please advice. :huh:  Thanks.  :laugh:
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #3 on: 24-September-05, 12:43:02 »
  • Best Answer
  • what version of windows do you have?
    have you tried uninstalling the software/driver through Add/Remove Programs?
    youngboyguy
    « Reply #4 on: 26-September-05, 04:43:45 »
    I try to do that. But there is not listed in the Add/Remove Program list.:nooo: Do u know any other way to remove it? :lol_anim:
    Thanks for reply.  :laugh:
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #5 on: 26-September-05, 13:12:42 »
  • Best Answer
  • can you answer questions asked of you?
    what version of windows XP? what bluetooth device?
    youngboyguy
    « Reply #6 on: 27-September-05, 08:30:49 »
    Opss......Sorry, did't aware of that.
    My OS is Windows XP Professional with SP2.
    MSI PC2PC Bluetooth
    Please advise :agrees:
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #7 on: 27-September-05, 17:56:25 »
  • Best Answer
  • is the device connected?
    youngboyguy
    « Reply #8 on: 28-September-05, 02:05:35 »
    Good day, what a good hint. Finally i saw the Bluetooth radio button already and successfully installed the MSI driver again. Hahh.......   :angel:
    1)Fisrt i connected my bluetooth, then i saw the Bluetooth radio button in device manager.
    2)Then i try to uninstall the Microsfot version bluetooth driver, it successfully uninstalled. But it will appear again once u re-plug in your bluetooth(bt) device.So, i just disabled it. Then it will have a X on the icon, mean the bt device not gonna connect with this friver.
    3)Another verion which is MSI proviced driver, i update the driver. And point it to the driver that i want(MSI driver) then update.
    4)Done.
    Hehhehe....really good hint, thanks a lot. Really from the bottom of my heart. Thanks a lot.  :agrees:
    Hope this will help others also.
