Author Topic: [VIA] KT4AV- No post, 8 beep  (Read 1773 times)
cozack
« on: 18-October-05, 14:40:33 »
Help me,
i have read all the stickies and try evrything, but didn't work. This mobo using xp2200 and 256MB ram.already test display card, ram with others pc and it works.
from stickies, 8 beep mean display memory read/write test failure. Is there any chance that mobo can be safe or repair. How?
thanks in advance
-Cozack
Lupin
« Reply #1 on: 18-October-05, 17:45:06 »
Hello!What type of RAM do You have?
Fredrik
  • There's always a risk.
« Reply #2 on: 18-October-05, 17:56:13 »
  • Best Answer
  • Do you know if the video card 1) is in completely, and 2) works at all. What is the graphics card?
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #3 on: 18-October-05, 18:19:25 »
  • Best Answer
  • can you list the specs of this system, as you have done in your sig, as it appears to be different to the one listed in your sig?
    try some different memory. if you have two sticks, try one at a time
    cozack
    « Reply #4 on: 20-October-05, 12:59:35 »
    thanks for the reply.
     graphic card and ram works fine when i test it with other MOBO. Graphic card is Geforce4 MX440 (AGP8X )with 64MB and ram is NCP 256MB PC2100.
    I already try change graphic card with PCI graphic crad and also AGP card, even try to use Kingston memory, all fail.. still got 8 beeps.
    does it means that mobo alreay died?
    osnavi
    • GENERAL
    « Reply #5 on: 20-October-05, 13:13:26 »
  • Best Answer
  • cozack: Before asking new questions, read Dr. Stu's post and tell us what is asked.
    MSI KT3 Ultra 2 ARU
    Athlon XP 2800+Thermaltake Heatsink fan
    2x 512 Mb DDR PC 2700 Spect
    MSI FX 5900XT 128 Mb
    SBlaster Audigy Platinum
    HDD 0 Maxtor80Gb HDD1 Maxtor120Gb both Ata 133-7200 RPM
    USB 2.0 HDD 80 Gb.
    MSI CDR 52x
    Aopen CDRW 48x12x50x
    Pinnacle DV500 VidEditor
    Thermaltake 420W 3.3v.-30A 5v.-40 A 12v-18A
    USB 1.1 Memory Stick Card Reader
    Floppy Drive
    PS2 & USBMouse
    WXP SP1
    cozack
    « Reply #6 on: 20-October-05, 14:01:35 »
    sorry..
    this is the spec that i can remember.
    - KT4AV mobo
    - Athlon XP2200
    - NCP 256 pc2100
    - AVF PSU 450W (voltage rail can't remember.. so sorry)
    - Display : Geforce 4 mx440 (64Mb 8x)
    - Seagate HD (80G)
    - Liteon Combo
    if u think that PSU is the problem, i don't think so, since already try with my enlight 350W (v rail can be read inmy sig).. nothing seems to work :undecided:
    hope its can help ypu guys to give me an idea how to revive it.
    thanks iin advance.
    - Cozack
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #7 on: 20-October-05, 18:08:17 »
  • Best Answer
  • voltages are same for all PSUs. Is your problem caused by your PSU? need to know the amp ratings
    cozack
    « Reply #8 on: 24-October-05, 13:25:40 »
    Dr. Stu, already tested with Enlight True Power that work fine with my Delta2 Mobo, it wont post at all even using only CPU, Ram and Display.
    Right now I al ready change that KT4AV with KT6 mobo.. and that KT4- throw away.. end of story.
    I dont think it can be revive again.. anyway, thanks for all the advise given, really appriciate it. Thanks again guys.
    - Cozack
