Author Topic: Msi k8t Neo2 Fir (bios upgrade)  (Read 1993 times)
WateRMan
« on: 19-October-05, 12:34:33 »
Hi.
I need help, i've a motherboard msi, msi k8t neo2, y have a AMD 3000+ venice, and i can't put de dual bank, i know that i have a 3.3 bios, and with this bios it's not posible, i need toi change for other bios (9.1 or 9.2). I know how to te upgrade, but when i upgrade the bios te computer don't working, only do 4 piii!! (the sound). I don't know what can i do. I tried with all bios posibble, until the beta, where is the bios's beta?
My pc:
MSI K8T NEO2
1GB 2X512 PATRIOT MEMORY DDR400 CAS 2.5
2X160 HD SATA
1X200 HD SATA
1X160 HD PATA
1X40 HD PATA
1X30 HD PATA
ASUS 6800GT 256MB
PSU 420W THERMALTAKE
(SORRY FOR MY ENGLISH, IF ANY PERSON SPEAK SPANISH WILL BE BETTER)
THNKZ
Hans
  • Official Q-Tec Alert Specialist // 正式Q技术机敏的专家
  • LIEUTENANT GENERAL
  • If I fix it, it will never need fixing again!
« Reply #1 on: 19-October-05, 12:50:05 »
  • Best Answer
  • The 9.2 bios is OK. Flash that one and reset the CMOS afterwards, using the JBAT-jumper on your board.
    Please, disconnect the computer from  the power-outlet when resetting the CMOS!
    You have a Q-Tec Power Supply? Change that first and come back later...
    * MSI P55-GD85, bios 1.3
    * Intel Core i7 860 (stock @ 2.8GHz)
    * 2x 2048MB TakeMS @ 1333MHz (8-8-8-24, 1T)
    * Club3D HD5770 1024MB
    * OCZ Vertex 2 120GB (OS and apps)
    * 5x Western Digital Caviar Green 500GB in RaID5 (storage)
    * 2x DVD Rewriter (LG, Optiarc)
    * PC Power & Cooling Silencer 750W
    * Cooler Master Stacker CM101
    * Dell Ultrasharp 2209AW 22\\\" (e-IPS) monitor
    * Windows 7 Professional NL
    MSI MediaLive: AMD Athlon X2 4800+, 2x1GB Crucial PC-4200, Seagate 160GB, Pioneer DVD-burner, Hauppauge PWR150 TV Tunercard, Windows 7 Home Premium NL.
    MSI X-Slim X620 :like: :like:
    Backup: Thecus N5200Pro NAS
    WateRMan
    « Reply #2 on: 19-October-05, 12:53:33 »
    ok, thnks, i will try it
    Tiresmoke
    « Reply #3 on: 19-October-05, 13:29:14 »
    https://forum-en.msi.com/index.php?topic=82164.0
    You may want to cruise our sticky posts as well.
    WateRMan
    « Reply #4 on: 21-October-05, 10:20:44 »
    HI again!!!!
    The problem with the upgrad is don't finish :(
    I know how to upgrade a bios, ( i have 13 years with computer's, i remember my amstrad, comodore amiga yet, lol) but i don't understand because this motherboard didn't want upgrade, I flash the bios, and turn off the computer the power supply get out, and reset de bios with jbat1 (like the boy of this forum tell me), but when turn on the computer dont work, only 8 pi (sound very quikly) like the computer don't want the bios. And i tried with all bios 9.1 and 9.2. Later that this do, i take a flopy and rescue the mb with amiroot.rom, with a flopy with the bios 3.3, and i tried with otre bios in other flopy with 9.1 and 9.1, but the mb don't want this bios, and i don't know what can i do....
    What is wrong?
    that i think i know how to flah a bios, its not my first time....
    anybody help me?
    thans a lot
    Tiresmoke
    « Reply #5 on: 21-October-05, 15:05:42 »
    What sockets is your memory in? Was the memory working in Dual Channel? Have yoiu run CPUz? If not please do and use the validate on the about tab and give us a link.
    felipedu
    « Reply #6 on: 31-October-05, 23:32:13 »
    Hi.
    My pc:
    MSI K8T NEO2
    2X160 HD SATA
    1X200 HD SATA
    1X160 HD PATA
    1X40 HD PATA
    1X30 HD PATA
    ASUS 6800GT 256MB
    THNKZ
    (FOR the guy that talk spanish)
    Hola, (Hi)
    la semana pasada tuve el mismo problema con una board similar. Intenté con varias marcas genéricas de memoria y no activaba el dual channel. Actualicé la bios a la versión 9.2 de acuerdo con una recomendación que encontré en este foro: 1º. Coloca una sola memoria en el slot1 y actualiza la Bios a la v. 9.2. Una vez se actualice la Bios apaga el PC y... 2º coloca los dos módulos de memoria, el primero en el slot 2 y el otro en el slot 4 y ya verás que funciona. (Last week i've had same issue with that board. Update the Bios to 9.2 version according to this forum: 1st. populate first slot with one memory stick and run the Bios update. Tunr off your PC and... 2nd populate slot 2 and 4 and you are ready.)
    El único problema que he encontrado con esta BIOS es que la tarjeta de video Gcube 9600XT presenta algunos saltos en los juegos. (The only issue about that bios version it's the GeCube Radeon 9600XT that  JUMPING in all games.)
    BYE!
     :yes:
    Tiresmoke
    « Reply #7 on: 31-October-05, 23:56:39 »
    This is an english language board here. Read the rules. We can't help you if we can't understand you and we do not allow other languages here. So please fix your post or I will delete it.
