Author Topic: Computer not shutting down  (Read 1022 times)
Zhar
« on: 21-October-05, 18:54:06 »
Whenever I try to shut down my computer, it simply restarts instead. It even does this when i press the button on my case to shut down. The only way to shut it down is to turn the power off. Does anyone know how to get around this? I have turned off "automatically restart" upon a system failure, but it still restarts. Thanks
Flow
  • SECOND LIEUTENANT
Re: Computer not shutting down
« Reply #1 on: 21-October-05, 19:11:31 »
  • Best Answer
  • In bios and in windows you need to disable wakeonlan.
    MSI K8N neo4 Platinum (bios 1.6),Amd64 xp3800+venice
     Corsair pc3200 2x512mb cas 2,2,2,5,
    HIS X1900XT 256MB-iceq3
    SB live 5.1 + 56k pci modem v92 trust,
    Asus dvd player + aopen dvd rewriter.Nec floppy drive
    maxtor200gb 8mb/7200rpm harddrive,
    Philips Brilliance 109P4 monitor,
    Coolermaster Centurion531 2 case fans + airduct,
    Coolermaster realpower 450w and WindowsXP Pro SP1.
