Author Topic: MSI K8N Neo2-FX - WinXP-sp2 USB problem  (Read 2469 times)
zet
« on: 08-November-05, 04:03:46 »
HI!
Two weeks ago I Bought this mainboard, and I can't install the Usb2 driver.
I have Windows XP with service pack 2, and it doesn't recognize the Usb ports as Usb2.
On the driver disc which were provided with the mainboard there were a driver, but only for the English version of WinXP-sp1.
My question is: Where can I get the drivers I need, or what did I wrong?
I downloaded all the stuff from this homepage, but these doesn't contain the %!!/@^ Usb drivers  :wall:  :wall:  :wall:  :wall:  :wall:  :angryfire:  :angryfire:  :angryfire:  :angryfire:
Pleeeeeeeese help!
Russ_xp
  • MAJOR
  • Folding 24/7
Re: MSI K8N Neo2-FX - WinXP-sp2 USB problem
« Reply #1 on: 08-November-05, 04:08:51 »
  • Best Answer
  • Win XP includes all drivers for USB / USB2 - the drivers on the CD are for Win 98.
    You need to go into the BIOS on startup, then access Integrated Peripherals , then Onboard Devices and set:
    OnChip USB
    This setting allows you to enable/disable the onboard USB controller. Selecting
    [V1.1+V2.0] enables the system to support both USB 1.1 and 2.0 spec. Setting
    options: [Disabled], [V1.1], [V1.1+V2.0].
    Then reboot and WinXP should detect and add the Enhanced USB controller under USB Devices.
    MSI K9A2 Neo (1.7), Phenom 9850 Black 0811BPMW DD-MCTDX
    8Gb (4x2) Corsair Dominator PC2-8500 5-5-5-15-2T, HD4870 EK-FC4870
    Hitachi 160Gb SATA2, HP 1070i DVDRW, PCP&C 750w 60A
    CM Centurion, XSPC 2xRS120, Bay Res, MCP655, Windows Server 2008 x64 Hyper-V, FAH_SMP+GPU
    MSI K9A2 CFv1 (1.7), Phenom 9600 B2 0743APMW DD-MCTDX
    4Gb (4x1) A-Data PC2-6400 5-5-5-18-2T, HD3870 XSPC Razor & HD3850 512Mb EK-FC3850
    Hitachi 160Gb SATA2 & 2x160Gb SATA-RAID, NEC ND3520 DVDRW, PCP&C 750w 60A
    CM Stacker, XSPC RS240, Bay Res, Eheim 1048, Windows Server 2008 x86, FAH_SMP+2xGPU
    Belkin UPS 1500VA, Belkin Switch2 KVM, Acer X222Wd, SC101 400Gb zSAN, 10Mbps Cable BB, Safe@Office500w
    PlayStation 3 - F@H 24/7
    zet
    « Reply #2 on: 08-November-05, 04:20:26 »
     :idea:  :idea:  :idea:  :idea:  :idea:
    Oh my!!!
    Thank you!!
     X-((  :yes:
    zet
    « Reply #3 on: 09-November-05, 03:28:58 »
    Well, the problem is still on.
    1) I read carefully the Instruction manual, and it says that there is no mistake, I REALLY have usb 2.0 ports. (8 pieces to be precise)
    2) In the BIOS I didn't find that option you mentioned.
      There are three options related to the Usb:
      a) Onchip Usb (enabled/disabled)
      b) USB kb/storeage support (enabled/disabled)
      c) USB Mouse support (enabled/disabled)
    I tried all the possible combination, but when i connect my pendrive to the computer it says (I don't know what the english Windows say, but I try to translate): This device is capable work faster, if you attach it to an USB2.0 port. (instead of saying "High speed USB Device is connected to a slower port", which appaers when using USB1.1 ports on an other comp.)
    What can you suggest????
    (I have sp2 with latest drivers possible)
    Russ_xp
    • MAJOR
    • Folding 24/7
    « Reply #4 on: 09-November-05, 04:36:35 »
  • Best Answer
  • What is the version of your BIOS - I think that 1.9 had a problem with missing USB2 ??  If you have that then flash to newer 1.B or back to 1.8.
    Seems I was right - READ this before you do anything else - https://forum-en.msi.com/index.php?topic=86257.0
    zet
    « Reply #5 on: 09-November-05, 07:02:04 »
    I Have already consulted some of my "expert" friends and they figured out that I need a BIOS update.
    So you just convinced me to follow their suggestions.
    I downloaded that bios update from msi homepage, refering to my motherboard's type. I think If I follow the instruction they provided, there shouldn't be any problems.
    So i'll run home right away, and hoping not ruining my mobo ;-)) tomorrow you'll be the first who wiill know the results
    Thanks again.
    zet
    « Reply #6 on: 10-November-05, 05:11:39 »
    It's Working!!
    no problem at all. the 1.b bios solved the problem. I still don't have that [diisable][1.1][1.1/2.0] option, but it works. :-)
    Feel free to delete the topic
