Author Topic: Additional help resources available here  (Read 11035 times)
StuTopic starter
  • Birmingham, UK
    • StuOnline.co.uk
« on: 04-December-05, 07:41:07 »
If you are trying to solve a hardware problem with your MSI Barebones PC unit, then this is the right place to look for help and post questions.
However, please take advantage of additional forums here to help with troubleshooting hardware related problems.
For MEGA PC 651, 865 and 865PRO
These are Intel P4 & Celeron systems, so you can find additional troubleshooting help in the Intel P4 & Celeron P4 based board. Please read through sticky topics there, and please also search in that forum, when searching for help.
Mega 651 is Socket478 SiS651 chipset based, Mega 865 is Socket478 Intel 865G chipset based, and Mega 865PRO is Socket775 Intel 865G chipset based.
For MEGA PC 180 and 400
These are AMD SocketA systems, so you can find additional troubleshooting help in the Retired Motherboards area. Please read through sticky topics there and also search there when searching for help.
Mega 180 is SocketA nvidia nforce2 18G chipset based, Mega 400 is SocketA Via KT400 chipset based.
For Mega MPC800K
This barebones system is based on Via K8T800 chipset for Athlon64 systems. If you are new to A64 systems, please read through stickies in the AMD64 Via based board forum, and try searching there too for tips.
For Axis 690
This unit uses the ATI RS690 chipset for Athlon64 systems. Please look through AMD64 ATI/Via/Sis board for anything that may be applicable to the problem you are having.
For Media Live
This unit uses the Nvidia C51PVG chipset for Athlon64 systems. Please look through AMD64 Nvidia boardfor anything that may be applicable to the problem you're having.
For Crystal A410, Hetis G31 and Quartz G31
These units are Intel Core2Duo / Core2Quad systems, so you can find additional help in the Intel Core 2 Duo/Quad boards area for anything that may be applicable to the problem you're having.
Please don't start barebones-related topics in those forums, but please do use those forums for additional reference, as many tips, tricks and advices will be applicable to barebones using similar chipset also.
