Author Topic: [Athlon64] RS482M4/RX480M4 Serie MS - 7191 Ver 1.1 Mainboard Resets itself  (Read 8303 times)
vitagoni
Small size mainboard with video and sound onboarded (LAN and all others as well)..
When listen any music from Windows Media Player or DVD (with sound) - it resets the system itself.
I use WinXP SP2.. It makes me a lot of troubles, I use music software and I must save projects constantly, terrible.
What's the solution? What's the problem?
What do I need to do?
Looks like it is because of Realtek onboard adapter, but I aware of buying another one unless I don'y know the cause.
Thanks
ant3202
  • FIRST LIEUTENANT
« Reply #1 on: 12-December-05, 15:57:27 »
  • Best Answer
  • more specfication on your computer ... u using wat type of RAM...
    chipset drivers installed?
    direct x to latest version?
    MSI 865PE Neo 2 - S Mainboard
    Intel Pentium 4 3.00Ghz
    Kingston DDR 2048MB - 400Mhz
    MSI nVidia GeForce FX5500 256MB DDR AGP 8X
    Seagate 7200.10 250GB HDD 7200RPM SATA
    Power Supply ~  Antec Earthwatts 500W
    Samsung SyncMaster EX2220
    Tiresmoke
    « Reply #2 on: 12-December-05, 19:09:03 »
    Is this in a machine you have built yourself or an OEM like an E-Machine or an HP?
    vitagoni
    « Reply #3 on: 13-December-05, 02:51:58 »
    Yes, I built it myself. GEIL 512 RAM, no FDD, Seagate Barracuda 7200 160G
    Video onboard, Sound also..
    Athlon 3400
    nothing else
    all drivers are from native CD..
    omni keyboard and msmouse
    vitagoni
    « Reply #4 on: 16-December-05, 02:41:47 »
    Ok, if nobody knows what's happening, then I suppose that this kind of boards is pretty RAW and was not tested enough. :nono:
