Author Topic: Gti200 DVI  (Read 2395 times)
Worm
Gti200 DVI
« on: 08-July-02, 20:44:51 »
Hi
We will gloss over the non working TV out :(
I have aVGA connected to analogue and TFT connected to DVI. SWoping  between the two has never been a problem.
However the DVI has suddenly become greyed out in properties.  I can connect the TFT to the analougue connection so the TFT should not be at fault.Have done a lot of fiddling with software ,so have I mucked something up anywhere
Or is the card hardware faulty? I need my DVI connection back!
TIA
Regards
