Author Topic: MSI live update  (Read 4740 times)
Flo
MSI live update
« on: 21-January-06, 22:46:00 »
how does this live update work? it flashes your bios? from windows?? online???  :bonk: is this safe>? sounds very sceary :shocked:
would like to know a bit more..
thanks ;D
birdone
  • SERGEANT
« Reply #1 on: 21-January-06, 23:38:38 »
  • Best Answer
  • Hi Flo,
    I can't say to you how this program work, cause : i never used it. A few days ago, i came here and ask how to flash my bios. And the guys (thangs again to them) said to me to NOT use liveupdate for a flash bios.
    They said  to read the stickys and the topics related to flashing. Read, read, and read again .. Then ask again  :cry:  It seems to be a heavy task, but nothing compare to kill a motherboard with bad flash.
    I was scared to flash cause i never do this thing, but with the good advice i saw here, i succeed.
    Good luck, and sorry, i didn't help a lot  :rolleyes:
    OLD Rig :
    7025 K8N Neo2 Plat. 54G (EasyBios3.1C3 by Syar)
    San Diego A64 3700 (260x10 //1.41V. Still testing..)
    XP-90 - SE2 Noisblocker
    6800GT PoV (def speed)
    2 x 1gig Ram PC4000  G-Skill HZ (Slot 1/2)
    Maxtor 6Y120PO ide
    HL-DT-ST-CD-RW GCE-8400B (not seen by EasyBios, but works ok !!)
    Samsung DVD-ROM SD-616
    Fortron Psu 500w Blue Storm V.2 ATX
    12V1 : 15A -- 12V2 : 16A
    3.3V : 30A -- 5V : 28A
    XP-Home
    New Rig :
    MSI P67A-GD65(B3) bios 1.9
    Core I7 2600K
    Noctua NHC12P SE-14
    2x4 gigas Ram G-Skill Ripjaws-x 8.8.8.24 (F3-12800CL8D-8GBXM)
    XFX Ati Radeon 5850 (11.5 drivers)
    SSD Crucial C-300 128 gigas (firmware 0007)
    Samsung Spinpoint F3 1to
    X-Fi Extrem Gamer Fatal1ty pro
    PSU : Enermax Modu 82+ 525W
    Windows 7 X64
    skippy9146
    « Reply #2 on: 22-January-06, 02:17:09 »
    There's a couple of reasons why using LiveUpdate is a bad idea -
    1) While flashing with it, there's always a chance (granted it's a small one) that your internet connection could drop out somewhere down the line & then you would be screwed. Time for a new chip.
    2) LiveUpdate doesn't always rewrite/clear parts of the BIOS file that it should. Which can leave you with a malfunctioning system at best, that could be re-flashed - that's merely a hassle or a throughly hosed BIOS chip at worst - Time for a new chip.
    Refer to the Sticky's at the top of the page for proper BIOS flashing methods/instructions.
    Flo
    « Reply #3 on: 22-January-06, 13:07:28 »
    Ahhhhhhhhhh ..... :yes: thats exactly what i thought and sceared for :shocking: thanks for the info.... i aint touching this prog!! no way thanks!!  ;D
    sswilson
    • FIRST LIEUTENANT
      • Hardware Canucks
    « Reply #4 on: 22-January-06, 22:46:29 »
  • Best Answer
  • Live update is still fine for updating everything but your bios.
    It does save having to hunt down the latest chipset/audio drivers and I've yet to hear any complaints about those updates.
    Just don't do a "live" bios flash.
    MSI 790FX-GD70 / MSI K9A2 Plat V1
    AMD 955BE / AMD 955BE
    OCZ PC3 12800 / PC2 1066 Firesticks
    4X EVGA 9800GT / 4X ASUS 9600GSO (Poor Man's Folding Farm)
    PC P&C 750W Silencer / Corsair TX750
    Modified Highspeed tech station case / Cheezy homemade tech station (motherboard tray with legs....   ;)  )
    Custom Water Cooling / Coolermaster Hyper 212+
    skippy9146
    « Reply #5 on: 22-January-06, 23:10:50 »
    ... could result in "dead" board! :shocked:
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #6 on: 23-January-06, 00:53:17 »
  • Best Answer
  • Quote
    not strictly true, the BIOS flash is downloaded BEFORE the flash takes place
    if you have to use LiveUpdate, then choose the option to create a bootable DOS floppy disk
    skippy9146
    « Reply #7 on: 23-January-06, 01:18:27 »
    I guess it all depends on the indivdual company's implementation - Back when I was a "noob" I had an ABIT board & used their version of online BIOS updating & ended up well & truly screwed.
    After that, I never use "live" updating anything.
