Author Topic: schematic for MS-7184  (Read 2771 times)
alexaversa
« on: 02-February-06, 20:50:32 »
I need to know where I can find a wire diagram or electrical schematic for my MS-7184 mainboad. Can you please help. I can't figure out how to post a new topic, so sorry for the reply.
Thanks
thanks for the reply NovJoe and Rookie
« Last Edit: 03-February-06, 19:31:54 by alexaversa »
NovJoe
  • Hawk
Re: schematic for MS-7184
« Reply #1 on: 03-February-06, 09:34:48 »
This is an OEM board. You'll need to approached your reseller for the manual.
MSI HQ Forum USB flasher
R00KIE
« Reply #2 on: 03-February-06, 13:20:02 »
i think you'll be out of luck, i don't think they will give you the schematic of the thing but it doesn't hurt to try
Glenn
  • HydroGen
  • Former Moderator
« Reply #3 on: 03-February-06, 22:02:29 »
No way you will be able to get a schematic because of NDA, that is unless you are an employee of the manufacturer.
I'll eat my cigarettes if MSI gives it to you. :lol_anim:   :rolleyes_anim:
You can however likely get info on parts if you get the right tech that want's to help you.
msi P55-GD65
i7-860 Lynnfield
G.SKILL Ripjaws Series 8GB (4x2) DDR3 1600 (PC3 12800)
Zalman CNPS9900A LED CPU Cooler
Diamond Radeon HD 3870 512MB GDDR4 Ruby Edition
Acer X203w 20" LCD
Samsung LN-T3253H 32" LCD HDTV
Kingston 128GB SSDNow V-Series
WDC Blue WD5000AAKS-22A7B2 500GB
Sony DRU710A DVDRW
Logitech Z-5500's
Creative Audigy2 ZS
Antec 300 Case
PCP&C Silencer 500 EPS12V PSU
Windows 7 (64bit)
