Author Topic: Mega Player 533- F/W v2.00.02 & Driver v1.672- Possible Problem & Fix to Recover  (Read 39656 times)
bickel72
RE: Firmware v2.00.02 & Driver v1.672 Update dated 06/04/06 for Megaplayer 533 - Model MS5533.
I think that there is a possible problem with the above Driver & Firmware Versions as they do not seem to work for the Mega Player 533 - Model MS5533 ???. It renders the player inoperable (ie.Unable to turn player on at all) and also makes the 256MB flash drive unrecognisable to the computer (ie. computer asks for a disk to be inserted into the flash drive, similarly like the SD Expansion slot) :wall:.
All Steps to update the firmware were followed to the letter, including no battery, updating to the new version of the driver software v1.672, formatting the drive at the same time and pressing sustained "play" button.
Possible Fix :idea:: I was able to make the player operable again by reinstalling the original driver software & rolling back the firmware version back to v1.00.06 again (Try original firmware v1.00.02 if you haven't saved the v1.00.06 Firmware to your hard drive, as MSI does not have any longer the v1.00.06 firmware on their website to download anymore ;-((). It now works as it did before  :D(unfortunately still with the "ROCK" setting bug) :cry:.
NOTE: In order for computer to recognise the drive, Press sustained "Play" button when connecting to the computer, then please go to "start" (below left corner) and enter "programs" and choose "MSI MEGA PLAYER MS-5533" then "Download Firmware".
Computer should then recognise the player and allow for the firmware update :lol_anim:
My main concern is that many of MSI's other unsuspecting customers will download this particular software and experience the same problems as I did. They probably won't be able to figure out how to rectify this issue & therefore unfortunately be left with a player that does not work at all :angryfire:.
I have logged this problem now with MSI, but have yet to hear a response from them.
Has anyone else out there experienced this same problem or is it just me??? ???.
I searched this forum for any similar posts for this problem but found none.
If I am doing anything wrong to update firmware v 2.00.02, please let me know.
I did notice however that driver v1.672 software for MS5533 was called a "Megastick" and NOT a "Mega Player". Is this possibly the cause of the problem as it is the wrong driver for the MSI 533 Mega Player - Model MS5533 ???. Any help with this would be greatly appreciated.
linhart.ondrej
I have EXACTLY the same problem! Sad to say I have deleted 1.00.06 firmware and 1.548.10.139 updater, so I downgraded to 1.00.01 firmware from original CD-ROM. Thank you very much for recovery solution bickel72 and I hope that MSI will solve this problem as soon as possible...
bickel72
I am glad to have at least helped one person, linhart.ondrej and I too hope that MSI will solve this problem as soon as possible. :biggthumbsup:
I am still waiting for an outcome to my logged problem with MSI. :think: Hopefully, not too much longer.
For those people who require a backup copy of the v1.00.06 Firmware from MSI for Mega Player 533 - Model MS5533, I have uploaded a copy on rapidshare. :grin:
http://rapidshare.de/files/18883282/MS5533_FirmwareV1.00.06.rar.html
If anyone has been successful with updating their Mega Player 533 to Firmware v2.00.02, please let me know.  :worship:
EDIT by Stu: firmware ZIP attached to this post!
linhart.ondrej
SUCCESSFULLY UPDATED TO 2.00.02!!!!! The problem was that you must keep play button pressed for entire updating process (very annoying but works). So, put off battery, press and hold play button and connect player to USB port (still hold button). With your other hand run firmware updater (version 1.672, still hold button), and check Format checkbox. Then start updating (still hold button). After update is completed you at last release button. Yes, it is 2.00.02 with fixed bugs and some new features!!!
Stu
  • Birmingham, UK
    • StuOnline.co.uk
  • Best Answer
  • :biggthumbsup: nice one guys, consider this stickied!
    bickel72
    Unfortunately linhart.ondrej I have already tried that particular technique and it was unsuccessful.  ;-((
    If you press sustained "play" button when connecting to computer, player is not recognised at all by the computer and the computer tries to locate the device over and over again but with no success.  :think:
    Please advise me of how long did it take to get your computer to recognise the device???, I tried holding the "play" button (when connecting to my computer) for over 10 minutes with no success. :wall:
    If you connect without sustained "play" button first, computer will connect properly and allow for the firmware download. If you THEN press the sustained "play" button during the firmware download (with reformat included), firmware update will succeed but will disconnect abruptly immediately after. (EVEN with the sustained "play" button still being pressed). If you then put a battery into the player, player is then inoperable & no longer works.(ie. it will not turn on at all).  :angryfire:
    In order to make the player work again, you have to reinstall the original driver software & roll back firmware version to v1.00.06 again.
    NOTE: At this time the screen actually shows that the firmware update was successful with v2.00.02 installed and with v1.00.06 to be reinstalled again. :think:
    I have tried several different techniques to update the firmware to v2.00.02 (including following ALL of the advised instructions from MSI) but none of them have been successful.  ;-((
    linhart.ondrej or anyone else for that matter who has or has not been successful in updating firmware to v2.00.02, could you please advise me of whether you were (1) Successful, (2) What operating system is being used by your computer and also (3) What Device Chip is being used in your Mega Player 533. (You can find this out in the Firmware Update Screen. If you click on the "Show Details" Button within this screen you will see it in the top right corner).
    My Details are as follows:-
    Operating System: Windows Millenium (Me)
    Player Device Chip: 3500
    Any assistance that anyone could give me would be great as I will be onforwarding all this additional info to MSI so that they may be able to assist me further with this problem. :biggthumbsup:
    linhart.ondrej
    Player was recognised in about 10 seconds, but now after updating to 2.00.02 player drives are not detected by computer so then nothing cannot be copied to or from player. This really starts pissing me off and spoils good image of MSI products. I hope that now I will be able to revert back to 1.00.01 firmware.
    bickel72
    linhart.ondrej, from the problem that you describe it may be only a driver software problem. ie Driver v1.672.
    Before you go & revert back to the original firmware v1.00.01, (NOTE: v1.00.06 Firmware ZIP is now attached to this post), try this possible fix.
    Possible Fix :idea:: Try reinstalling the original driver software from MSI Original CD-ROM and see if the computer now recognises the drives properly.
    If this turns out to be the cause, I believe the whole problem may be with Driver v1.672 and not the v2.00.02 Firmware Update. Then again, my particular problem could possibly be a combination of the two (since I cannot update firmware to v2.00.02 at all). :angryfire:
    Please let me know how on you go, so that I can notify MSI of any results. :biggthumbsup:
    NOTE: Could you please also refer to my prior reply post (dated 28 April 2006) and advise me of your particular details, so that I can update MSI with my logged problem. Any help that you could give me would be greatly appreciated.
    linhart.ondrej
    Player firmware 2.00.02. Uninstalled 1.672 driver and installed driver from original CD. Drives are now recognized by Windows XP (but you must press and hold play button when connecting player to USB port, otherwise nothing is recognized by Windows or by firmware upgrading application), but these drives are not accessible. Firmware upgrading application shows messagebox "Media state not recognized.". I try to restore 1.00.01 firmware, (I cannot use 1.00.06 provided by you, because newer version of firmware upgrading application (driver) is needed). Chip version of my MS-5533 player is 3500. And one notice: When I connect player to USB port and restart computer, it freezes with blank screen when Windows XP (Service Pack 2) is booting. Also player works in USB 1.0 mode although my USB ports are all 2.0 version.
    10 minutes later...
    I successfully downgraded to 1.00.01 and player works fine like new. Everything is correctly detected and drives are accessible. So MSI is responsible for this by posting functionless firmware and drivers. Hope that they will correct this very soon (I contacted their technical support and they simply copied and pasted instructions from firmware download page as reply - unbelievable).
    bickel72
    linhart.ondrej from what you say it appears that both Driver v1.672 and Firmware v2.00.02 are faulty. :angryfire:
    I have pretty much given up on this upgrade version (if you can call it that). Looks like I am going to have to wait for the next instalment of driver & firmware versions from MSI (if any).
    Like you, my initial logged problem to MSI Technical Support got the copy and pasted instructions from the MSI firmware download page as a reply. I then further elaborated on the problem with a detailed response query but to this date MSI have not replied and the query status remains as "open".   :think:
    I am not aware of what driver version is from my original CD-ROM, but you can upgrade to Firmware v1.00.06 with it. I have uploaded a backup copy of this MSI Mega Player 533 - Model MS5533 driver on rapidshare.  ;D
    http://rapidshare.de/files/20262928/MS5533.zip.html
    Note: Unfortunately Firmware v1.00.06 comes with the "ROCK" setting bug.
    Refer to the below topic by Hotarm.
    https://forum-en.msi.com/index.php?topic=91816.msg659395#msg659395
    I have never used Firmware v1.00.01, so I do not know how good or stable it is (especially when you compare it with the unstable v1.00.02) but v1.00.06 seems to work OK (with the exception of the bug described above).
    If MSI ever reply to my logged problem with a solution, I will advise of the outcome on this post.  :biggthumbsup:
    abc
    I followed every step bickel72 sent me and it worked fine. @ bickel72  Thank you once again.. :biggthumbsup: Hope MSI can solve this problem or atleast remove that F/W update which is no good at all..  :nono:
    Questioon
    Briefly, it is possible to install/use firmware version 2.00.02 as seen...
    http://something.atspace.com/Gallery/Images/1.jpg
    http://something.atspace.com/Gallery/Images/2.jpg
    PS: Sorry for poor image quality. All I have was a cheap webcam at the moment.
    Edit: I noticed that direct clicking does not work but you can copy paste USL's into browser's address bar
    bickel72
    Questioon, congratulations on being successful.  :biggthumbsup:
    Unfortunately, the problem is that Firmware v2.00.02 & Driver v1.672 does not seem to work for everyone. ;-((
    There have been several cases (including myself) where these particular Firmware & Driver Version updates have not been successful & have actually left the Mega Player 533 inoperable afterwards, no matter what techniques were used to update the software (including MSI's Website Instructions).  :wall:
    Could you advise since upgrading your Mega Player 533 to Firmware v2.00.02 did you get the same problem as linhart.ondrej, where the player drives are now no longer being detected by the computer so that nothing can be copied to or from the player. :think:
    Also, it would be very informative if you could tell us:-
    (1) What operating system is being used by your computer.
    (2) What Device Chip is being used in your Mega Player 533. (You can find this out in the Firmware Update Screen. If you click on the "Show Details" Button within this screen you will see it in the top right corner) and
    (3) Was there anything different in the procedure that you used that allowed you to be successful with the firmware upgrade to v2.00.02?
    Any further details that you could provide would be greatly appreciated. ;D
    Questioon
    Actually it is a long story including 2 other 533s which are fried (literally) during upgrade process.
    Here are some of my experiences...
    After completion of one of my upgrade attempts  I inserted battery and get "usb power surge" message when plugged. That rendered the device inoperable with the battery. It was still recognizable by windows both as recovery and storage devices depending on pressing/not pressing start button before plugging.
    To be sure I checked the usb voltage of my PC  with a multimeter and it was about 4.5 volts on load. During my countless :) plugging unplugging attempts I accidentally noticed that if I connect USB cable sort of half way (like only dc power pins connected but data pins not) device was able to start as mp3 player. I mean original mega logo appeared and device was able to play mp3s as normal. Then I made a special usb cable to try to power it with 3 serially connected AAA cells (~4.5 volts total) via USB port. And surprise,... it was working. So for a couple of days I used it with that external battery pack. It was big and ugly though. And I gave it to a friend who likes customized! devices : ).
    And here is what I did to install latest firmware into my second 533:
    1) I deleted all file instances and registry traces of old 533 driver and downloader versions both automatically (by uninstaller) and manually (coz related sys file was still there, in system32\drivers folder and maybe also in driver backup after automatic uninstallation). Also maybe it is necessary to perform a complete search because despite I deleted the related sys, windows was able to install recovery device  probably from its driver backup folder. I also deleted related oemxx.inf from \inf folder (be careful, don’t delete the wrong oemxx.inf ones belong to other devices). Because windows rename/recopy original *.inf into oemxx.inf.
    2a) I put firmware files from zip into driver installation package's bin folder.
    2b) Again I put firmware files from the zip into c:\program files\msi\... after installation (though this step is probably unnecessary)
    3) I removed battery, pushed the button, plugged in, windows recognized it as recovery device, after about 5 seconds   (not too long coz a device timeout occurs sometimes, and if this happens unplug and replug while still pressing the button)  started software, now device was disappeared from hardware list momentarily and re-recognized as storage volume.
    4) Here I get an error message like "operating system error..." It was impossible to use software with the device recognized as "recovery device". I unplugged and re-plugged now without pressing the button, device was recognized as usb storage volume and I started the software and upgraded the firmware. Device was inoperable...
    5) Repeated the process, now with pressing the button. I upgraded the firmware. And everything was OK. Rock EQ fault was gone. A playlist function is added, hough I dunno how to use this  as yet : ) When I go into playlist option I’m unable to exit, and only way I found to exit is turnoff. Except this detail it works properly.
    My computer is a standard Dell latitude c600 (an old model with one USB-1 port only), with windows xp spII. Device chip is stmp3502 according to latest driver but it was a stmp3500 according to driver on the cd came with the device.
    Hope this helps,
    Best regards.
    PS: Despite the whole adventure :) I really like this device, its plain design, SD card feature, removeable battery, and especially its stmp35xx chip, also used in ipod shuffles which is regarded as best sounding ipod model, by some people.
    PS 2: Maybe this is known to everyone, but I just noticed that it is possible to play non-compressed wav files with maga player 533 (16 bit 44.1 khz stereo PCM files). All you have to do is copying them into "voice" folder of the device. Then you have CD quality audio. I dont know whether it is possible with older firmwares too, or just a feature of latest one.  I also tried higher quality formats like 24 bit 48 khz but device couldnt see these ones :)
    linhart.ondrej
    It is our only hope that MSI will release new FULLY FUNCTIONAL firmware and driver soon.
    abc
    Hope this helps,
    Best regards.
    anyone tried this procedure? did it work?didn't work for me..  ;-((
    v2.pain
    I finally solved "the v2.00.02/v1.672 firmware update problem" [after 20 install/reinstall edited for languiage]
    [I also tought (at the time) that my player is dead/fried...doesn't matter now dough..]
    It's almost funny now how easy I made it to work again with updated firmware..
    point is that when you connect it on USB without pressing anything and start updater
    and when it says "Media state not initialized" you check "Format" and run it..when completed
    unplug it..and then again connect it with play pressed all the time (as described in instructions)..
    start updater again with format option checked and wait to complete..thats it!
    now finally everything works fine as it should be (v2.00.02).. :agrees:
    P.S. "Questioon" wrote that he didn't figured how to work with playlist..just, when you are in the "playlist", need to press next/previous key for about half a second to navigate through folders (when you copy music to player you put it in folders if you want to use playlist feature)
    v2_no_more_pain_manual
    Questioon
    Thanks for explanation about playlist.
    And actually your solution looks similar (same maybe) to my last steps (step 4-5) I mentioned above.
    Interesting :)
    abc
    Don't mind my post earlier, it works.. tanx. :agrees: :biggthumbsup: :agrees:
    bickel72
    It appears to me that the method described above by Questioon & v2.pain only seems to work for people with Windows XP;-((
    Please let me know if I am wrong. (I unfortunately have Windows Me). :worship:
    Would you believe that I am still waiting for a response from MSI Online Technical Support (Request was Originally Sent 15/04/2006).  :think:
    Like I said before, I am now content to wait for the next instalment of driver & firmware versions from MSI (if any).  :biggthumbsup:
    v2.pain
     :wall: Does anyone know where or in which country you can use frequencies from 65 MHz-125 MHz FM..which I can now search/scan when I listen radio on my MEGA-mega :agrees:-(5)533..for those who don't know some guy named Garry Sun (he is maybe from MSI who knows) posted file "stmpsys.sb", topic is "Expand frequency from 65 Mhz to 125 Mhz in MSI-533" https://forum-en.msi.com/index.php?topic=99116.0, which I installed (updated firmware again just with this file instead original in v2.000.002-fw).
    P.S. [to bickel72]: I don't know why don't you just find someone with XP windows and update firmware there [it takes about 2 min to install 1.672 drivers and FW-v2..and than format it and update firmware] and than use it on your winMe at home [if your only problem is win XP ..maybe I don't understand what your problem is..I don't know anyone who still has win Me so I can't try it myself].
    P.S.2. It still amazes me how resistant MEGA 533 is ..to all this installs/formats  :bonk:..I even unplugged the USB cable during format process just to see what will happen..nothing..after reinstallation it worked again..in all I maybe formated it and reinstalled it for about 25-30 times until I made it to work as it should..at the time I even made it to work with v2 fw but it was showing 000.000.000 version for "Boot Manager" in updater prog. details and I thought that was some kind of bug and it is normal and I used it for a week until i started to mess with it again until I succeded :shocking:
    linhart.ondrej
    I finally solved "the v2.00.02/v1.672 firmware update problem" [after 20 install/reinstall Edited for language]
    edited for language. Same problem as I mentioned above. Firmware update successfully completed, but player does not start and drives are not recognized...
    Tiresmoke
    watch the language folks. This is the family channel and I will enforce it if this keeps up.
    abc
    No problems here.. been using my mega player for about 3 weeks now. (OS: winxp)
    rpphorums
    Just a note that I installed that new firmware and driver, and all went okay. I did take out the battery and kept the button down before and during the whole process, like the instructions say. Also formated the volume. The most unnearving thing was that upon connecting the device (whilst holding the button down) I received a message from my operating system saying that a USB v2.0 was connected via only a v1.0 port (even though I'm pretty sure the port is v2).
    I then received 'Playlist' function. So now I can navigate throughout the folder tree and select all the files/folders I want to play. Although you only have one playlist, it is still a good feature, vital I'd say for my personal needs.
    I notice that when I sometimes rearrange the device's files from the computer, that the device hangs upon next boot up. I'm guessing that it fails if it can no longer find folders/files last recorded on its playlist. So if that happens, I remove the system file in the root folder (I can't remember the name, offhand) that it uses to record the playlist files, and all seems to be okay.
    Never having used an MP3 player before, it took me some time to understand how to construct a playlist. The new English manual certainly doesn't tell you. grrrr, that's very slack MEGA.
    I've also noticed that when I'm finishing the playlist and I wan't to navigate out of the root folder, I can't hold that left-button down too long, else it reboots.
    I also had problems determining the play order of files/folders. Most of the time it seemed to be alphabetical, but sometimes not. I think the play order is alphabetical but only the first 6(?) characters of the file name / folder name are significant. So the beginning part of all my file/folder names look something like 01.01. The "Title" (an MP3 tag?) that you can set is what is displayed on the unit's interface, but it does not determine the play order.
    I've turned the backlight off, and that seems to conserve a lot of power.
    At the moment, I'm pretty happy with the unit. The only thing I really miss is a built-in rechargeable battery. That would be sweet.
    The quality of the built-in recording is quite good (for voice, anyway). I was surprised that it only records to WAV, and has no MP3 option.
    It's a pity there was so much time wasted stuffing around with dowloading and installing firmware, drivers and manuals. And figuring out how to use the thing - THAT IS NOT DOCUMENTED PROPERLY.
    G3R1NC
    I didnt manage to do this...
    Could somebody please write down clearly what do I have to do? I have Mega Player 533 without radio, I think its not problem, but tell me if it is...
    I tried everything...
    The Playlist function would be very useful for me
    Please help!!!
    spadayu
  • Best Answer
  • I have had the same problem and I solved it.
    1. flashed it to firmware v.2.00.2
    2. device was death
    3. installed old drivers from CD
    4. I have pressed play button, but player was recognized like as "recovery device".
    5. driver installation window pop out and I browsed it to CD:\\533Setup\MSI\Drivers\StMp3Rec.ini file
    6. after everything installed player was flashed to v.1.0.1
    7. disconnected the device
    8. then I've uninstalled old and installed new drivers MS5533 driver V1.672
    9. copied firmware files to specified dir C:\Program Files\MSI\MS-5533\
    10. push the play button and started update program
    11. the player was flashed to  firmware v.2.00.2
    12. disconnect it, connect it, if it don't work try 10. and 11. step w/o pressing the button
    13. or try everything from 4. step but pointing to new driver unpacked folder
    good luck
    Tiresmoke
    Nice post Spadayu... This should help folks understand that step by step.
    korner12
    hey... i need a msi mega player 533 original firmware(v1.0.0.2 or 1.0.0.6)... pls add here...
    bickel72
    The link that Stu added earlier (ie. 29 April 2006) on this main thread should help you out with your request.
    It appears to still be valid.
    MSI MS5533 Firmware v.1.00.06 zip file link
    https://forum-en.msi.com/index.php?action=dlattach;topic=96066.0;attach=2061
     :biggthumbsup:
    Vashtard
  • Best Answer
  • so based on the whole topic it seemed the new software driver is the cause of the problem....
    i thought my Mega Player 533 128mb ver, is doomed beyond my cause..... as i tested to connect and reconnect my player until it reads "recovery" and downgrade my firmware to 1.00.06 (which is in my original firmwear ver. in my player)
    and i did a very nasty procedure due to my laziness and i thought it fried my player because i forgot to take out the batt... and even almost killed my player in the process....
    based on my carelessness did it happened to you when you left your earphones near the player that causes most of the text to go jibberish... =P
    y0shi007
    hello guys, i lost my original driver CD can anyone post or upload the drivers? pls. my mega player 533 is dead and i need to fix it..
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
  • Best Answer
  • y0shi007,
    have you actually read through this thread? ???
    you can find all downloads and information for this product here:
    MSI MegaPlayer 533 series
    mArlInJ
    Hi all,
    I have same problem. but my player can't recognize by computer after update firmware.
    Can't open.
    how do i do? or shop new one. :bonk:
    steve_h
  • Best Answer
  • Hi all,
    Well after a hour or so I've cracked it ...   :hat tip:
    The DRIVER installed files (ver 2.6) from the MSI website  :nooo: are BAD / corrupt ... so heres the workaround ...
    I haven't isolated the exact file(s) as some are resourse for others but if you do the following you should get the 533 working
    Simple: replace DRIVER installed version 2.6 files with FIRMWARE (download zip) files and manually run upgrade from folder.
    Detail: Go to program files, msi, ms-5533
              Delete or rename the six (6) files of the same name that are in the FIRMWARE downloaded zip file
              Copy the files from the FIRMWARE extracted folder to the ms-5533 folder
              Connect 5533 and Run stupdaterapp.exe by double clicking on it
              Follow the prompts ...
    (Note to MSI reps - I need work or freebies / hardware)
    Greets to Claire :biggthumbsup: @MSI
    Kengoor
  • Best Answer
  • I hate this.... I tried to update the software and now my player is dead! I can't even turn it on, or connect it to computer! I can't get it back to older version because it is not recognize by my system.... What do I do???? :( And I tried to hold the PLAY button! Still nothing!
    gars
  • Best Answer
  • i cant make my 1 gig sd card work while my unit is on, it just kept flashing the hour glass and the mega logo waited for almost an hour but to no avail but i managed to update its firmware and i really liked the playmode/playlist function the only problem is i can only put music on the built in memory but when i use it as a card reader my cards work
    Byokugen
  • Best Answer
  • any1 still has v1 firmware for this?
    Mike
    • aka Frankenputer
    • Virginia, USA
  • Best Answer
  • Logged
    #1:
    #2:
    MSI Wind U100
    bokica
  • Best Answer
  • 1. download driver 1.672 and firmware 2.00.02
    2. install driver
    3. copy firmware files to C:\Program Files\MSI\MS-5533\ ,REMOVE BATTERY from mp3
    4. press and hold on/off button on mp3 (and hold all time)
    5. connect mp3 with usb to comp
    6. start/programs/msi run aplication
    7. chek empty slot and click start (mp3 delete all files,and upgrade new files)
    8. remove mp3 from usb and remove finger from button on/off ;)
    9. put battery in mp3, if is mp3 die, try same job again u make something wrong, i finish job in 3 trys.
    10. connect mp3 to comp and download mp3 files
    enjoy :))
