Author Topic: kt3 ultra bios 5.7//..what is fastest cpu i can use?  (Read 3072 times)
poopsy
i have a 1.5 athlonxp now and wonder if i can seriously use a 3000+ 333 mghtz? ..or should i use a 2600+ 266? I know what msi says from their support>>2600+ 266 is max  but can i use a 3000+ 333 and if i can what do i need to do to get it to work properly...i have pc2700 333 memory in their now too(3-512 sticks)  thanx
  • T9246ED, Бивша комета
  • Administrator
  • Online Online
« Reply #1 on: 07-May-06, 18:18:46 »
  • Best Answer
  • helo welcome to forum. look into your manual and find out maximum FSB support by your mobo. that will answer your quesion.
    poopsy
    « Reply #2 on: 07-May-06, 19:19:16 »
    thank you..i know its max from msi says 266  2600+  but it seems a 3000 or 2800+ will run 333 mhtz..if you change the bios setting to 166 ...but..i also wonder how much faster is a 2800 or 3000+ 333  then the 2600+ 266 chip?  anyone know?
    poopsy
    « Reply #3 on: 07-May-06, 19:59:40 »
    AMD ATHLON XP-2600+ PROCESSOR
    SOCKET A, Pin-Grid-Array (PGA).
    2.13 GHZ, @ 266MHZ FSB
    128KB L1 and 256KB (on chip) L2 Cache
    3DNow! Professional Technology (72 instructions, full SSE compatibility)
    VS
    ATHLON XP 2800+ SOCKET A (266Mhz BUS) WITH QUANTISPEED ARCHITECTURE OPERATING AT 2.083GHZ OEM VERSION
    VS
    ATHLON XP 3000+ SOCKET A (333Mhz BUS) 512K CACHE WITH QUANTISPEED ARCHITECTURE OPERATING AT 2.16GHZ OEM VERSION PULLS
    (Purchase a fan to extend the warranty from 30 days to 1 year)  AMDXP3000333OEM
    IT WOULD SEEM THE XP2600+ 266 IS FASTER THEN THE 3000+ 333...IS THIS TRUE? THANK YOU
    • Administrator
    • Online Online
    « Reply #4 on: 07-May-06, 20:05:24 »
  • Best Answer
  • "IT WOULD SEEM THE XP2600+ 266 IS FASTER THEN THE 3000+ 333...IS THIS TRUE? THANK YOU"
    nop. 3000+ at 166FSB(333) is the fastest one from thease 3 choices. Due to bigger FSB speed 166 vs 133 as other 2 CPUs and twice bigger Secondary level Cache (512KB) His code name is Barton.
    Grayone
    • LIEUTENANT GENERAL
    « Reply #5 on: 07-May-06, 20:07:01 »
  • Best Answer
  • Is your motherboard a KT3 Ultra 2 or a KT3 Ultra?  The version 5.7 bios only works with the KT3 Ultra 2.
    If it is an KT3 Ultra 2, then you can use an XP-3000 with 333fsb in it if you manually set the fsb speed to 166.  The difference in performance between the 2600 with 266fsb and the 3000 with 333fsb is noticable if you play games or do folding with your computer but I don't know what percentage it is.
    DKA790GX Platinum w/Phenom II 960T unlocked to 6 cores
    4 gig GSkill DDR2 800 @5-5-5-15-2T
    N460GTX & N450GTS
    Corsair 650TX  12v-52 amps
    Windows XP-SP3
    G31-M7 w/Q9400 @3.28GHz @1.312v
    2Gb DDR2 800 @5-6-6-15-2T
    GTX460 Hawk video card
    Seasonic 520 Watt S-12 12v-40amps
    Windows XP-SP3 - Folding 24/7
    poopsy
    « Reply #6 on: 07-May-06, 20:53:32 »
    i have the kt3 ultra..latest bios...my question is even on the 300+ 333 i have to redo the buss to 166..right...and the 2600+ 266  is the same meghrtz right? 2.13   ..so...whats the big diff then? thank you
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #7 on: 07-May-06, 20:59:03 »
  • Best Answer
  • http://en.wikipedia.org/wiki/Front-side_bus
    In complex image, audio, video, and scientific applications where the data set is large, FSB speed becomes a major performance issue. A slow FSB will cause the CPU to spend significant amounts of time waiting for data to arrive from system memory.
    poopsy
    « Reply #8 on: 07-May-06, 20:59:44 »
    so a 2600+ 266 chip has less cache..ok(1/2 of 512)..and are you saying the fsb on that chip automatically adjusts to 133...whereas the 3000+ has a fsb of 333 but you have to go into the bios and put 166 in the buss setting?  so couldnt you set the fsb of the 2600+ 266  to 166 as well?  if so then the issue left is the 512 cache on the 3000+  vs the 256 cache on the 2600+..right? i am a bit confused..sorry...
    Grayone
    « Reply #9 on: 07-May-06, 21:53:34 »
  • Best Answer
  • Your thoughts are going in the right direction but some other things need to be considered as well.
    You might be able to overclock the 2600 to a fsb of 166.  This will cause the cpu to run hotter and will require an effecient cpu heatsink.  A jump in the vcore of the cpu may be necessary for it to reach a fsb of 166 and more heat will be generated.  This additional power must come from the power supply so that has to be checked to see if it is capable of providing the extra power.
    Extra case cooling might also be needed to get rid of the extra heat so there are a lot of thing to consider before simply raising the fsb on a cpu.
    What is the price difference between the two cpus?  Is it worth the extra work and possible cost?
    You will still have only a 256 L2 cache once the cpu is overclocked so a higher fsb will be needed to offset the level 2 cache difference between a 2600 and a 3000.
    N460GTX & N450GTS
    Windows XP-SP3
    Fredrik
    • There's always a risk.
    « Reply #10 on: 07-May-06, 21:58:37 »
  • Best Answer
  • Been away a while, but I think the matter is automatic recognition. That is, even though the 3000 is at 133, the processor is correctly recognised when Ratio is set to Auto.
    As said above, level 1 cache is a major thing. That is for example one of the reasons Athlons work so much better than Pentiums at equal MHz.
    I'd advice against setting to 166 on this mobo, as that is a major overclock.
    And Grayone is of course more thorough on this and other points.
    Mr Wulf
    « Reply #11 on: 08-May-06, 09:22:23 »
    Your mainboard will not accept 3000+ processor!  The bios version does support 3000+ processor but the mainboard does not!(Remember, you are using the same bios as for the kt3 ultra 2 mainboard)
    Please only use up to 2600+ processor.  The Barton processor is the same size and will fit into the socket(A) but is not compatible with your mainboard.
    On the other hand, it sounds like you really want to try with 3000+ anyway.  So try it and post the results.
    osnavi
    • GENERAL
    « Reply #12 on: 08-May-06, 15:41:41 »
  • Best Answer
  • Well, a lot has being said in this matter, so you could try searching related posts in the Forum. But as being told you, the problem is not only if Mobo will support 166 FSB, but also you need at least PC 2700 Memory, besides good cooling and perhaps a better P.S.U. It would be easer if we know your PC specs.
    MSI KT3 Ultra 2 ARU
    Athlon XP 2800+Thermaltake Heatsink fan
    2x 512 Mb DDR PC 2700 Spect
    MSI FX 5900XT 128 Mb
    SBlaster Audigy Platinum
    HDD 0 Maxtor80Gb HDD1 Maxtor120Gb both Ata 133-7200 RPM
    USB 2.0 HDD 80 Gb.
    MSI CDR 52x
    Aopen CDRW 48x12x50x
    Pinnacle DV500 VidEditor
    Thermaltake 420W 3.3v.-30A 5v.-40 A 12v-18A
    USB 1.1 Memory Stick Card Reader
    Floppy Drive
    PS2 & USBMouse
    WXP SP1
    poopsy
    « Reply #13 on: 08-May-06, 19:56:04 »
    thanx...i have a 2800+ coming to try...i see the 2600+ 266 chip online..its fast at 2.17 gighrtz but the cache is only 256...is this really a huge deal?   maybe i should just use the reccomended chip then...i am confused..i have a huge psuply and cooling..so i am ok there....whats odd is the speed of the 2600+ chip is more then the 2800+ 333 chip but the 2800+ has a 512 cache..whereas the 2600+ has only 256 cache...hm...
    Grayone
    « Reply #14 on: 08-May-06, 20:10:39 »
  • Best Answer
  • Yes, and the 2800 also has a front side bus speed of 333mhz where the 2600 has a 266mhz front side bus.  Data moves faster along a faster bus so the 2800 is actually a faster cpu than the 2600 because of the faster front side bus in addition to a larger L2 cache.  The 2600 has to run at a faster internal speed than it does now to equal the 2800's ability to process data.
    An example: The slower Athlon 64 processors run at only 1.8 ghz, slower than the 2600's 2.13 but are able to process a lot more data due to their much faster front side bus speed.
    Hope that this explaination helps to explain the relationship between processor internal speed and front side bus speed.
    N460GTX & N450GTS
    Windows XP-SP3
    Stu
    • Birmingham, UK
      • StuOnline.co.uk
    « Reply #15 on: 08-May-06, 20:52:24 »
  • Best Answer
  • AMD's "Performance Rating" is quite simple really; an XP2800+ is better than an XP2600+ ;-))
    Fredrik
    « Reply #16 on: 09-May-06, 00:56:41 »
  • Best Answer
  • A swap from 2600 to 2800 processor - for me - doesn't seem worth the effort, or the risk.
