Author Topic: How do I flash the BIOS without a CPU on the Tomahawk b450?  (Read 19679 times)
0 Members and 3 Guests are viewing this topic.
andrei391Topic starter
Hi, I've never purchased a MSI product before but this will be my first one, I'm wondering how do I flash the bios with the Flashback+ button.
I'm looking for the new Ryzen 3000 series and I don't have any older cpu to flash the bios and I've heard that with this Motherboard I can flash it without even a CPU on it!
Thanks beforehand
Marked as best answer by andrei391 on 25-June-19, 08:20:17
rbleroy91
  • RBL_FR
This mobo has Flashback+, so a CPU is not required to update bios. To use it do that:
- Download >>Bios V1.82<<.
- Extract then copy the file "E7C02AMS.182" on the empty root of the USB pen (no more than 16GB and FAT32 (not FAT) partition).
- Rename "E7C02AMS.182" to "MSI.ROM".
- Power off.
- Plug the pen in the Flashback+ port on the back panel:
- Power on and wait 5s.
- Press the Flash Bios button on the back panel (see upper figure).
   Does the Flash Bios LED (+ USB pen light if there is) flash (you could have to wait around 2mn)?
     . If definitvely not, try with another USB pen because Flashback+ seems to not recognize some model (I don't know why).
     . If yes, be patient because load process can run up to 10mn.
- If Flashback+ has goodly ended, power off PSU, unplug the power cord and wait 10s after all mobo's leds light off.
To finish, one remark: if you do not use a Ryzen 3000, load rather >>Bios V1.50<< (E7C02AMS.150). V1.70 and 1.82 are buggy for current CPUs and AMD (not MSI) refuses any downgrade from them (fortunately a tool permit to do that).
Have a good day,
:hat tip:
- Power off.
Have a good day,
:hat tip:
Woooow! Really useful, thanks a lot!!
rbleroy91
  • RBL_FR
You are :welcome:
Have a nice day,
:hat tip:
insanityrisel
- Power off.
Have a good day,
:hat tip:
I Have a question, i have a b450 gaming plus Mobo freshly bought, should i just download the **latest** bios and follow this procedure? (I have ryzen 5 3600 processor and no older gen processor). I am not sure if i have to download the latest driver or just the one that corrects that issue.. Thanks in advance
rbleroy91
  • RBL_FR
Yes, you can use Flashback+ to load direcly >>Bios V1.B2<< (E7B86AMS.1B2).
Have a good day,
:hat tip:
insanityrisel
Have a good day,
:hat tip:
Thanks my friend for the fast answer ! Anyway the latest bios is somewhy not available and i think they have realesed it today. So i will stick to the version right before the beta One that has just been released. Thanks again
insanityrisel
Re: How do I flash the BIOS without a CPU on the Tomahawk b450?
« Reply #7 on: 01-September-19, 04:51:24 »
Hi again.. i just wanted to be 100% sure.. so you said that i have to install the latest bios right and not just the one that implements new ryzen processors support? I am asking this because msi bios updates are very small sized and that makes me think that they are "progressive updates" which means that one update doesn't implement the features of the previous one..can you clarify this to me please?
rbleroy91
  • RBL_FR
No, they are not incremental but full updates. You can load directly the last available bios retailed version: V1.A0. Load the beta version (currently, V1.B4), who is also a full update, only if you have issue with the previous retailed one.
Have a good day,
:hat tip:
insanityrisel
« Reply #9 on: 04-September-19, 15:35:32 »
Okay man thanks a lot, i have another last question for you..the only usb pen drive with a led that i have is 32gb of memory..wil be that a problem? Or should i stick with a non led pen drive of 8gb? I am scared , i don't want to break the mobo thanks in advance !
rbleroy91
  • RBL_FR
Use the 8GB pen drive even it has not LED. Look at the bios flash LED to see if update process works:
- At start, the LED should flash quickly 3-30 times then light off 10-90s,
- During update (up to 10mn), it should flash slowly.
- At end, it should light off (for recent mobo models, the pc should even shutdown or restart).
I am scared, i don't want to break the mobo
Once bios file copied and renamed on the pen drive, it should be a good idea to verify it with CHKDSK. If there is error, format it, copy-rename the bios file and redo a CHKDSK.
Have a good day,
:hat tip:
insanityrisel
« Reply #11 on: 04-September-19, 15:55:17 »
Thank you a lot !! ♥️You saved me !
rbleroy91
  • RBL_FR
« Reply #12 on: 04-September-19, 16:18:49 »
You are :welcome:
:hat tip:
insanityrisel
« Reply #13 on: 05-September-19, 13:04:43 »
Hi i tried this procedure and Everything seemed to have gone well. Then i started my pc, it didnt't ask me to configure the bios or anything ,there was just a screen saying "plug in any data drive to install an operating system" or something like that. So i restarted and i started installing windows using my pen drive..at 50% of the installation the red ez cpu debug led lighted up and the screen(not the pc) shut down. Now i tried unplugging the power cord and restarting but now the cpu led is lighted up and i can't do anything..
I had this problem before(i thought to have tighten too much the heatsink to the cpu) and reinstalling the cpu with the heatsink seemed to solve that. But after the system crashed during the installation i am not sure
if it is a bios problem or if i have to configure something.
NOTE: i didnt't plug the reset switch into the mobo because i read that it could make conflicts.
NOTE #2: i installed the latest NOT beta bios.. i have a ryzen 3600.
What can i do??
insanityrisel
« Reply #14 on: 05-September-19, 13:10:50 »
In case i have to reflash the bios.. do i have to unplug everything from my mobo or just the processor(with the heatsink)?
rbleroy91
  • RBL_FR
It is not required to unplug components, even the CPU. Flashback+ needs only the PSU but it can work will any other component in place.
Have a good day,
:hat tip:
rbleroy91
  • RBL_FR
:biggthumbsup: Flashback+ has worked!
I had this problem before (i thought to have tighten too much the heatsink to the cpu) and reinstalling the cpu with the heatsink seemed to solve that. But after the system crashed during the installation i am not sure
What can i do??
Bios is not the culprit. I suggest to open another topic because your problem is not related to bios flash. Give all your configuration, including PSU and monitor models. Explains also the problem and what you have tried.
See you soon,
:hat tip:
insanityrisel
« Reply #17 on: 05-September-19, 18:11:41 »
:biggthumbsup: Flashback+ has worked!Bios is not the culprit. I suggest to open another topic because your problem is not related to bios flash. Give all your configuration, including PSU and monitor models. Explains also the problem and what you have tried.
See you soon,
:hat tip:
hi, at the end i changed the bios with the beta one(latest) and now i don't have any problem at all ! Thanks again for all the support given !
rbleroy91
  • RBL_FR
« Reply #18 on: 05-September-19, 23:42:33 »
Good news, happy for you! :pompom:
Glad to have been able to help.
Have a nice day,
:hat tip:
rsigha03
« Reply #19 on: 25-February-20, 13:22:43 »
Hi does it work on any msi motherboard and any processor ?
rbleroy91
  • RBL_FR
« Reply #20 on: 25-February-20, 16:34:08 »
Hi does it work on any msi motherboard?
1/ Flashback+ is available only on some mobo, not all MSI.
and any processor?
2/ CPU is not required to run Flashback+.
Have a good day,
:hat tip:
PS : if you have another questions, do not resurrect old topics but open a new one
