Author Topic: New computer keeps rebooting randomly  (Read 601 times)
virtualtoTopic starter
« on: 12-December-19, 16:28:54 »
Hi all,
I just got a new computer and it keeps rebooting randomly. Can't pinpoint what makes it crash, sometimes it goes for hours with heavy workload, sometimes just after startup. I've used both the Intel  XTU and manual Bios settings posted here by Krank (thanks, very helpful cause I'm a complete noob when it comes to OC) but I can't figure it out. Could you post some settings for my setup or help me pinpoint the issue? At this point I would be even happy to have some safe non-OC default settings to keep it up
Here are my system's specs:
Main board:________MSI MPG Z390 GAMING EDGE AC ATX W/ ARGB 802.11AC WIFI USB 3.1 3 PCIE X16 6 SATA3 2 M.2 SATA/PCIE
Bios version:______E7B17IMS.A71
Video card:________NVIDIA GEFORCE RTX 2060 SUPER 8GB GDDR6
PSU brand & model:_APEVIA 800WATT GOLD 80 PLUS POWER SUPPLY
12v rail of PSU:___66amp (https://uploads-ssl.webflow.com/5ced3cdc3850586f0800b1a0/5d800649ada7fe9905411e6a_um-prestige.pdf)
CPU:_______________OEM INTEL CORE I7-9700K 3.60GHZ 8/8 12MB CACHE LGA1151 95W (COFFEE LAKE)
Memory:____________32 GB TEAM T-FORCE DELTA RGB 8GB DDR4-3200 BLACK (4 x 8GB)
SSD/HDD:___________240GB ADATA SU630-240G SATA-III 6 GB/S SSD + 1TB HDD 3.5 SATAIII 7200RPM
CPU cooler:________ASETEK 550LC 120MM WATERCOOLER + THERMALTAKE RIING 120MM HIGH STATIC PRESSURE WHITE LED FAN
RAID card:_________N/A
Sound card:________ONBOARD 7.1 SOUND
Keyboard:__________CYBERPOWERPC MULTI-COLOR LED GAMING KEYBOARD
Mouse:_____________CYBERPOWERPC ELITE PRO M1 131 RGB GAMING MOUSE
Addl hardware:_____LOGITECH PRO FLIGHT YOKE, RUDDER & THROTTLE
OC:________________YES
Operating System:__Win 10 Pro 64bit
Thx,
To
Chike
  • GENERAL
Re: New computer keeps rebooting randomly
« Reply #1 on: 12-December-19, 16:54:45 »
What is your max vid under heavy load?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #2 on: 12-December-19, 21:24:30 »
Sorry I don't understand the question. How can I tell?
Chike
  • GENERAL
« Reply #3 on: 12-December-19, 21:28:24 »
Monitor them with HWiNFO (sensors) or HWMonitor
CPU: i5-4670k
« Reply #4 on: 13-December-19, 06:28:32 »
Thanks for the reply. Max VID under HeavyLoad is 1.325V.
HeavyLoad didn't cause any issues, but I had both Prime95 and MemTest64 causing crashes so I think there might be an issue with the RAM
Chike
  • GENERAL
« Reply #5 on: 13-December-19, 06:56:29 »
Yes I know heavy load does not cause issues, but we need to know what may be needed.
I forgot to ask, what is actuall vcore also.
Set cpu core voltage to 1.325v and see if it helps.
You can try lowering it until monitored vcore is the same as max vcore you had on auto.
CPU: i5-4670k
« Reply #6 on: 13-December-19, 08:14:41 »
Max VCORE is 1.320V
MemTest64 passed and so did MemTest86+ passed. No crashes... :think:
Thanks for helping!
Chike
  • GENERAL
« Reply #7 on: 13-December-19, 08:29:41 »
Start with 1.32v cpu core voltage then. see how this goes.
Another option that works for some is adaptive + offset +0.025v
https://forum-en.msi.com/index.php?topic=327051.0
CPU: i5-4670k
« Reply #8 on: 13-December-19, 11:03:10 »
I will try this out, thank you!
« Reply #9 on: 14-December-19, 20:26:41 »
It seems like your settings have worked, I haven't had a single crash since. I still don't understand what the issue was. The power was too low?
They're anyway, you helped me very much!
Chike
  • GENERAL
« Reply #10 on: 15-December-19, 04:08:51 »
:welcome:
I don't know if it's simply low voltage, it may be more complicated than that
CPU: i5-4670k
