Hello MSI fans,
Here comes the beta version of fan control application for MSI laptops.
System Requirement:
1. MSI SCM utility must be installed.(Except for Skylake version)
2. For Windows 7, please install .NET Framework 4.0.
For Windows 8/8.1, please install .NET Framework 4.0 or newer version.
3. Require administrator privilege during the installation.
4. Only supports on some models.
Please refer to the model list in PDF file for Haswell and Broadwell.
>> Supported Model List
5. Only supports MSI branded models.
Simple Introductions:
1. Download and extract the installer to your local disk, right-click setup.exe, and select "Run as administrator" to install.
2. Restart Windows, and it will become a resident process in the System Tray. Double-click the Silent Option icon to open it.
3.Default settings screen.
Haswell, Broadwell
Skylake version
4. Simple mode (Haswell, Broadwell)/ Basic mode (Skylake)
Haswell, Broadwell
Skylake version
5. Advanced mode
Haswell, Broadwell
Skylake version
6. Advanced mode allows you to backup the customized values.(Not available in Skylake version)
| Silent Option Version | Silent Option V1.0.1510.2301 | Silent Option V1.0.1603.3101 |
| CPU Generation | Haswell, Broadwell (Intel? Core? i7-4xxx/Intel? Core? i7-5xxx) How to identify CPU Generation? | Skylake(Intel? Core? i7-6xxx) How to identify CPU Generation? |
| OS | Win 7 32-bit / 64-bit,Win 8 32-bit / 64-bit,Win 8.1 32-bit / 64-bit, Win 10 32-bit / 64-bit | Win 7 32-bit / 64-bit,Win 8 32-bit / 64-bit,Win 8.1 32-bit / 64-bit, Win 10 32-bit / 64-bit |
| Download Link | http://download.msi.com/uti_exe/SilentOption_1.0.1510.2301.zip | http://download.msi.com/uti_exe/SilentOption_v1.0.1603.3101.zip |
| Released Date | 2016/5/6 | 2016/5/6 |
| Required SCM before installation | YES | NO |
System Requirement:
Haswell, Broadwell
Skylake version
Haswell, Broadwell
Skylake version
5. Advanced mode
Haswell, Broadwell
Skylake version
