- Nov 20, 2003
For this board, use this tool instead:
For your board use that one:Hello, I like to update my z270 sli plus (ms-7a59) from 1.80 to latest possible ( 7A59v1A ). Can I do this with Forum Tool or use some other method?
Thanks in advance.
This:Hi i am new here which version of the tool should I use to downgrade B350 PC Mate bios version? Thanks for your help.
But for your 3xx chipset, it may brick it. It depends of specified BIOS to which BIOS. [gse to regular]For your board use that one:
https://forum-en.msi.com/index.php?...ell-flash-tool-v1-19-for-msi-boards-✔.343010/
Thanks again @SvetThis:
Can't be tell in advance, but for 3xx boards in some case the switching is not working correctly for all cases.
see here tested way:Hello, I'm new here. Which tool version should I use to downgrade the B350 PC Mate bios? I appreciate your support.
Details about that you can find here:Hi all, I have a MSI P67A-G45 (B3) with BIOS version is 1.J. Which tool should I use to update the BIOS from 1.J to 5.4? Any guide? I found older threads on this but the links they have are broken![]()
Thanks, I posted here why I was thinking of updating the BIOS:Details about that you can find here:
However if you have no issues, no need to flash your BIOS.
Yes.In any case, the link for the tool is broken on that post, will it be the "tool96" mentioned on this post?
You can't do this then with this CPU, because it's supported since BIOS version 7B84v2IHi everyone, I have MSI B450 PRO M2 mobo. I want to downgrade it from 7B84v2I to 7B84vAD. Which file should i use if i have R5 5600x?
